Mach Discussion => General Mach Discussion => Topic started by: scottn on May 03, 2008, 01:44:02 AM
Hi everyone,
As you can see, the site has undergone a bit of a facelift. It's not flashy, it's not awe-inspiring, but hopefully it's a tad bit more user-friendly... :)
If I've forgotten anything, or if you find something broken (I *think* everything is functional, but it is 3am... ;) ), please let me know...
(edit: I see that the forum sometimes looks a little freaky with the new CSS, depending upon what screen it's showing - I'll check that out)
Good night!
scott
Thank you! :)
Hello Scott,
Hey good work on the new look ,just one thing I try to use the link to the older version of Mach and got the same page as the downloads,here is the question Do this versions ,the ones on the downloads page are the only versions available?
Thank You,Marco.
Hi Marco,
When you click on the link for previous versions, it should open up the FTP server (which may take 10-15 seconds). If you're using Firefox, you should be able to see all of the connection stuff happening down in your Status bar. IE isn't quite as transparent - it kinda looks like it's sitting there, doing nothing, and then all of a sudden it'll pop open. None of the links on the Download page should link back to the Downloads page itself, though...
To answer the question - every previous version back to 1.84.002 is on the FTP server... :)
(ftp://machsupport.com/Mach/)
scott
Hello Scott,
Thank You for the fast responce,now I went and try again and got from IE the page where it tells You there is a problem,wtih the web site or spelling,I try the link that You send to My email and got the same result. I will try mozilla and let You know.
Thank You,Marco.
Hello Scott,
problem fix with again a different aplication that is not microsoft >:(
I use mozilla and took like 1/2 second. ;D Thank You,Marco.
Hi Marco,
I have tested everything with both IE6 and IE7, and everything appears to work fine for me (except for the main menu under the logo - IE6 doesn't properly handle transparent backgrounds, and it's not worth trying to find a hack for it), so I'm not sure why your IE was giving you problems (could possibly be a security setting). I'm glad to hear the Firefox worked for you, though... :)
scott
Hello Scott,
Thank You for the help,Marco.
Very nice.
IE7 works for me - :)
Good work Scott.
Could you please add the link to the users videos to the top nav bar.
http://www.youtube.com/groups_videos?name=artsoft
Every video is and advertisment for mach, as well as a testimony that mach is versatile.
Thanks, Benny
Hi Scott,
In general features at end of first paragraph is {insert more text}
Cheers,
Bob
Good work Scott.
Thanks, Benny
Hi Benny,
Done!!... :)
Hi Scott,
Cheers,
Bob
Hi Bob,
Doh! Good catch... all better now... ;)
scott
Done!!... Smiley
Good work.
Do you dare update the forum software? Its really outa date. With known security issues. (Its been lucky they havnt been exploited.)
I would set it up from scratch in a different section and swap it across once its is working right.
Things to look out for are the links section plugin, and the other plugins I have already installed.
The only reason I didn't update was I knew there was going to be lots of incompatibility issues with the current plugins. That been said, the new software is more update friendly for future updates.
Good luck :)
Yes, I'm going to update everything... :)
I have a sandbox setup at home with the forum running on it - I'm going to update that first (and find out what breaks and how to fix it), then update the live forum here. The current plan is to get it done sometime within the next 7 - 10 days (after Brian and I get home from the UK)... :)
