Mach Discussion => VB and the development of wizards => Topic started by: tantan on April 24, 2008, 11:36:25 AM
hi again,
i have the next macro which runs perfect except for the [ code "G04 P2.0" ] part. i am sure the subroutine is executed but the output is not latched for 2 seconds. i hope someone can help me because it is an essential part of my machine. (i run mach3 2.63 version on windows xp).
'SetUserDRO(1200,GetSelectedTool())
'OldTool = GetOEMDRO (1200)
wantedtool = GetOEMDRO (1200) 'GetSelectedTool()
MaxToolNum = 8 'Max number of tools for the changer
If newtool = wantedtool Then
Message ("Selected Tool already loaded")
Exit Sub
End If
'While wantedtool > MaxToolNum
'Tool = Question ("Enter New Tool Number up to " & MaxToolNum)
'Wend
While wantedtool <> newtool
Call actualtool
Call rotateCW
Wend
Call stop_and_lock_turret
'//// Subroutines /////////
Sub actualtool
If isActive(Input1) And isactive(Input2) And isactive(Input3) And Not isactive(Input4) Then
NewTool = 1
End If
If isActive(Input1) And isactive(Input2) And Not isactive(Input3) And Not isactive(Input4) Then
NewTool = 2
End If
If isActive(Input1) And isactive(Input2) And Not isactive(Input3) And isactive(Input4) Then
NewTool = 3
End If
If isActive(Input1) And Not isactive(Input2) And Not isactive(Input3) And isactive(Input4) Then
NewTool = 4
End If
If isActive(Input1) And Not isactive(Input2) And isactive(Input3) And isactive(Input4) Then
NewTool = 5
End If
If Not isActive(Input1) And Not isactive(Input2) And isactive(Input3) And isactive(Input4) Then
NewTool = 6
End If
If Not isActive(Input1) And isactive(Input2) And isactive(Input3) And isactive(Input4) Then
NewTool = 7
End If
If not isActive(Input1) And isactive(Input2) And isactive(Input3) And not isactive(Input4) Then
NewTool = 8
End If
setcurrenttool(newtool)
End Sub
Sub rotateCW
ActivateSignal(Output6)
While IsMoving()
Wend
End Sub
Sub stop_and_lock_turret
DeActivateSignal(Output6)
While IsMoving()
Wend
ActivateSignal(Output5)
Code "G4 P2" 'Wait for the tool to rotate onto ratchet stop
While IsMoving()
Wend
DeActivateSignal(Output5)
While IsMoving()
Wend
End Sub
thanks
antoine
the netherlands
just a note,
remove the "While IsMoving(), Wend" statements from your activate and deactivate signals they are pointless there. The while is moving is for Movement type coded commands, i.e. Code "Gxx ...." it is used when you want to wait for the machine to move, this includes the G4 codes.
scott
thank you for your reply,
what i want with the "G4 p2.0" is that the output 5 stay high for 2 second and then it has to be deactivated. is that possible with the G4 code the way i used it in mach 3 (lathe)?
yes, the way you have it written will work, just only have the while is moving after the G4 only not the activate and deactivates signals
i am sorry but i do not understand fully what you mean with your latest reply (probably because i am dutch).
what i understand is that i should delete the While IsMoving() function. but can i use the G4 command to delay the activation or deactivation of outputs or is the G4 function not the right one to use for my case?
if i cannot use the G4 command to delay the activation or deactivation of output what function should i use. or do i have to solve this in by hardware?
thanks
antoine
the netherlands
G4 is the correct function to use for a delay. G4 can measure time in either seconds or miliseconds, there is a check mark on the config screen to select.
While IsMoving is only needed on commands that cause motion, it is not needed on the activate output or deactivate. I dont think it will hurt, but it is not needed.
The following should work
While IsMoving()
Wend
End Sub
hi,
thank you for your reply. I cannot get the code statement working. i open a vb window, type just the commands:
Code "G4 P2"
then i compile and run the program. the program ignores the code statement!
another strange thing is that my outputs 1 2 3 and 4 on my first i/o card can be switched on by the statement ActivateSignal(...). the output 5 and 6 just pulse with the same statement. does that has something to do with hardware or has mach trouble with outputs 5 and 6.
thanks
antoine
How do you know its ignoring the G4?
try this simple test program:
code "G4 P10"
While Ismoving()
Wend
MsgBox "time done"
when I run it in the script editor there is a 10 second delay before the message box appears.
Are you sure output 5 and 6 are setup correctly? Be sure the port number is 2 if they are on the second parport.
hi ron,
you are right. your test program works fine. the problem is in my hardware. u use 2 parallelports; one (LPT1)on the motherboard of the computer and one extra PCI port. the outputs connected to the first port (lpt1) work exactly as they should. but if i use the same program to control the outputs on the second port they just pulse. if i write a VBscript with one line: activatesignal(output6), output6 is high for just a 0.1 second or so.
i don't understand the difference between the two ports?
thanks antoine
hi ron
I AM SORRY, i found the problem. let me explain to you what i did.
i began thinking why the outputs of the second port could be disabled almost immediately after is enabled them. i early day i have been programming PLC's. when that happend in PLC's most of the time i had used the specific register twice. this was exactly what happend i my system. a few months ago a have made some test programs in brains. i used the output 5 and 6 and these programs where still enabled in brains control. i disabled the specific brain and everything works fine now.
i hope it did not keep you awake....
thanks Antoine
Always good to hear when an answer is found. There are many places in Mach for that kind of duplication. I have had several problems with macropumps using the same DROs as my wizards.
Hi ron,
I am doing quite well with my ATC for my emcoturn120 but i hope you can spend a little more time for me. my code is actually working completely as a button script. When I copy the code into the M6start macro, and I type T2 or another T6 request in the MDI the macrocode is executed but…..
If I type T6 in the MDI line, I would like to change to the sixed tool. How can I pick up the wanted toolnumber in my m6start code. As soon as I type T6 and the M6start.m1s is executed the “newtool=getselectedtool()” is forced to zero.
i did a little test with the next instruction in the M6start macro;
MsgBox ("newtool = " &GetSelectedTool())
if i type T3 in the MDI line, the m6start runs automatically but the selected tool is resetted to zero.
(i reinstalled mach3 and did no configuration changes; so it is a fresh an clean installation).
i hope you can help me again, i think i am almost there
Thanks for your reply.
antoine
I am having the same trouble with my macro. It appears to me that when the m6start macro runs the tool number is the old tool, not the one we are changing to. I think when m6end runs the tool number has been changed.
I have a message in to Brian to get help on this, when I get it figured out I will post more here.
OK, I have some updated info. If you check the box in config/general that says auto toolchanger then only the m6start runs. The m6end is only used when you do manual tool change.
Are you entering the full command- " m6 t0303" I dont think T3 alone works.
thanks again ron,
using the full statement seems to bee the trick. i am gone try this on my emco and i think my toolchanger will work.
antoine
the netherlands
