Mach Discussion => General Mach Discussion => Topic started by: bbrown2005 on April 16, 2008, 12:52:57 PM
hi i have an error message on my mach 3 mill that says abnormal condition when i move my poiter over it it reads g90/g91 does anybody no what that is thanks bn
Are you loading code or is it just as you start Mach? Try putting G91 in the MDI line and pressing enter.
it is there when i start i does not effect movement i can load g code and it does fine it is always flashing i tried typing g90 g91 in mdi and nothing thanks ben
Please attach your xml so we can have a look. You will find your xml in the Mach3 folder, you will have to rename it before the forum will accept it as an attachment.
Hi, Ben
If everything is working and operating fine, You must have changed or run some G-code that set Mach or Left Mach in a different Normal Condition/Abnormal Condition.
I don't have a list of these item's, But it can be as simple as running some G-code that leaves Mach in a G91 inc. mode,
If your Normal Condition on startup is G90 abs. mode, The button will flash green/yellow.
With the Msg you have, A g90 or g91 on the MDI line should re-set/fix it.
To reset the Normal Condition/Abnormal Condition, green/yellow flashing back to Green, Just Double-Click on the Button and say yes to the Prompt Msg.
Thanks, Chip
thanks for the help. everything is working even when it flashing. i tried double clicking and that works. i could not figure out how to post my xml. the only thing i found was xml. backup but windows would not let me save it on cd-r.
Hi, Ben
Sounds like you sorta got it sorted out.
Chip
