Mach Discussion => General Mach Discussion => Topic started by: suthy on April 13, 2008, 03:46:11 PM
Hi cnc'ers
New to cnc and have not long had mach3 and a romaxx cnc, I'm after some advice on cad programs for the beginner I've tried vcarve pro which is good but a bit highly priced for a newby
Any-suggestions
Are you looking for CAD or CAM? CAD is a drawing programme, CAM takes a drawing and produces toolpaths from it then gives you G-Code.
There is a CAM programme that comes with Mach, its called LazyCAM and should be installed when you installed Mach. Its still Beta but may do what you want. Also if you look at the Links button at the top of the forum you should see some links to CAD and CAM programmes.
Cheers Hood I'll have a look
