Mach Discussion => General Mach Discussion => Topic started by: yahuie on April 11, 2008, 10:51:49 PM
I was running a program when the machine started a x axis move before reaching the correct y axis point. I checked the program which is correct. There were also no missed steps. I don't know what caused this. Is there anything that could make mach not complete a line before moving to the next? I have turned off the screen saver. Should I also turn off the 'auto off' function for the monitor?
Any ideas would be appreciated.
Bill
Please attach your xml, I had this happen a while back and when I compared a saved xml and the present one there was a difference. I cant remember what it was but maybe if I see your xml it will jog my memory.
What you describe here. is similar to what Spinnetti has posted on another topic on this forum (Code wanders off)
In my case setting the "look ahead" to 1 seemed to help
Jan
