Mach Discussion => General Mach Discussion => Topic started by: montejw on April 06, 2008, 05:05:17 PM
Title: Probing plugin records Z up as well as Z down?
Post by: montejw on April 06, 2008, 05:05:17 PM
I just started probing and looked at the output .txt file and see that the retraction point (Z up) is being recorded as well as the contact point (Z down).  Is that correct?  Doesn't seem like I'd want those points.
Monte
Title: Re: Probing plugin records Z up as well as Z down?
Post by: stirling on April 08, 2008, 06:33:25 AM
Can't help you directly because I was unable to get the probing plugin to work at all. However it certainly seems on the face of it unnecessary to record the rectraction Z level.
It was because I was looking for a little more than the available probing routines offer that I started http://www.machsupport.com/forum/index.php/topic,4352.0.html
You may want to take a look at http://www.razordance.co.uk/probe25D.htm if you don't want to plough through the whole thread.
Ian
Post by: montejw on April 08, 2008, 11:01:59 PM
That looks great.  I'll give it a try, thanks.
Monte
