Mach Discussion => General Mach Discussion => Topic started by: ian3846 on April 06, 2008, 05:27:54 AM
Hi guys just wondering if somebody can identify this motor below is all the info i have on it.
BRUSHLESS DC SERVO MOTORS 24VOLT 10AMP
HIGH TORQUE OUT-RUNNER DESIGN
THESE MOTORS ARE EXTREMLY HIGH QUALITY SERVO MOTORS OUT OF ELECTRONIC DEVICES
THEIR DIMENSIONS ARE 105mm IN DIAMETER AND 80mm IN LENGTH WEIGHT 1.5Kg, THEY MAYBE MOUNTED BY JUST ONE END OR BY BOTH ENDS. THE MAIN BODY IS THE ROTATING ELEMENT HENCE THE NAME "OUT RUNNER"
THEY HAVE THE CONVENTIONAL 3 PHASE WIRING AND ALSO HAVE HALL EFFECT SENSORS. THEY HAVE BEEN TESTED ON BOTH SERVO AMPLIFIERS WITH HALL EFFECT SENSORS, AND ON MORE SIMPLE RADIO CONTROL SENSORLESS CONTROLLERS.
DUE TO THEIR HIGH TORQUE DESIGN THEY ARE WELL SUITED FOR MILL OR xyz TABLE APPLICATIONS
