G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: brand468 on May 12, 2006, 06:18:54 AM
Title: Lazy Cam 2
Post by: brand468 on May 12, 2006, 06:18:54 AM
Hi Brian,
I have some trouble with Lazycam 2.0 and MachIV 1.90.036.
When i import an image and make an raster image conversation, and post to g-code im not getting any Z-values.
It is working fine in MachIV 1.90.028.exe release, do i miss something or is it a bug?
Christer
Title: Re: Lazy Cam 2
Post by: Brian Barker on May 12, 2006, 10:45:04 AM
I think it is a bug :( I will hav to look at the output class.
Thank you
Brian
Post by: brand468 on May 12, 2006, 11:22:56 AM
Ok, thank you  :)
Christer
Post by: brand468 on June 10, 2006, 09:38:15 AM
Hi Brian,
Any progress on this problem, still miss the Z-value when i try Image to Raster function?
Best regards
Christer
Post by: Brian Barker on June 11, 2006, 08:40:48 AM
It is getting worked on today, sorry for not getting to it sooner
Post by: brand468 on June 11, 2006, 09:06:48 AM
Hi Brian,
No problem, just want to check if i missed some update.
Christer
Post by: Brian Barker on June 12, 2006, 06:53:45 PM
I found the problem and I have fixed it :)
I have a few more things that I am working on so it is going to be a few days till the release is ready..
Just wanted to update you  ;D
Brian
Post by: brand468 on June 13, 2006, 02:17:51 PM
Hi Brian,
Ok fine, thanks for your update.
Christer
Post by: brand468 on June 24, 2006, 12:33:18 PM
Hi Brian,
Just want to check when you think the new version will be out?
Have some wood engraving that i have to do. :)
Regards
Christer
Post by: Brian Barker on June 24, 2006, 04:10:16 PM
I think it is out now...
Post by: brand468 on June 25, 2006, 02:14:32 AM
Hi Brian,
I have downloaded Version 1.90.052 from Arts page and i have the same problem with the included LazyCam 2.53.
Maybe Art forget to update LazyCam?
Regards
Christer
Post by: Brian Barker on June 25, 2006, 06:40:08 AM
I just sent the code to Art so he is up to date now :) I will post here when it is updated.
sorry about that
Brian
Post by: brand468 on June 25, 2006, 06:57:14 AM
Hi Brian,
Thanks for the update  :)
Christer
Post by: Brian Barker on June 25, 2006, 08:00:54 AM
It is all updated and is part of .52 release of Mach3 :)
Post by: brand468 on June 25, 2006, 08:20:21 AM
Hi Brian,
Downloaded and installed, LazyCam version is 2.54.
Loaded jpg image into LazyCam and the Raster XY and i get a "Bad character on line nuber #9"
It seems lika a "N55" is inserted, I edit it manual and then it seems to work fine,
Thanks Brian
Christer
N5 (File  )
N10 (File Posted in Mill Mode)
N15 (Sunday, June 25, 2006)
N20 G90 G80 G40 G91.1
N25 G0 Z1.0000
N30    X0.0000 Y0.0000
N35 M3 S100
N40    Z0.1000
N45    Z1.0000
N50 N55 M3 S100
N60    Z0.1000
N65 G1 X0.7000 Z-0.4000  F100.00
N70    X1.4000
N75    X2.1000
Post by: Brian Barker on June 25, 2006, 08:23:40 AM
I will Get this fixed tonight :)
Thank you
Brian
Post by: Brian Barker on June 25, 2006, 10:31:43 AM
Should be fixed :)
Thank you
Brian
Post by: brand468 on June 25, 2006, 10:41:56 AM
Thank you Brian, :)
I wounder if you could consider to make the raster angle selectable in feature versions?
It seems like a angle of 30 degrees or so make the picture better looking (see http://www.vectric.com/WebSite/Vectric/pvc/pvc_index.htm)
Keep up the great work  :)
Christer
Post by: Brian Barker on June 25, 2006, 11:12:05 AM
I can look into it ...
