Mach Discussion => General Mach Discussion => Topic started by: mwb on May 11, 2006, 11:09:10 AM
When I first start up Mach 3 mill I have a problem with the MDI. After homing the machine I enter an
absolute position using G90, but I get no response. If I enter a G01 to any position it will move as
requested. After the G01 command, the G90 will respond, however it moves at feed rate and not
rapid. Thanks for any help.
Mark
Try entering G00 G90 (xpos ypos) This should make it move at rapid to the position that you would like.
