Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: BigZ on March 20, 2008, 08:55:39 PM
I have successfully installed a webcam to my machine.
My problem is when using the Mouse move function the machine moves correct in the Y axis direction but the opposite to what it should for the X axis. I have tried flipping the image and rotating the camera but to no avail. I am wondering if it has to with reversing my Z axis in the Config Homng /Limits.
The other problem is the 'Show positon' and 'Mouse Position' are not legible when enabled.
Liam
I have too some problems with this plugin. the nastiest issue is the inverted movement (in my case) on Y axis.
How did you fliped the image ?
I tried flipping the mage but it didn't help. It also made manual jogging harder.
