Mach Discussion => General Mach Discussion => Topic started by: greek12r on March 20, 2008, 08:17:16 AM
hello, everyone,
i'm having a problem when i load a g-code from lazy cam to mach 3. The thing is that when i load it the first time i can see it all without any problems with the g-code. If i close mach 3 or regenerate it, then i can only see half of the image and the g-code is bad!
am i missing something?
please help!
thanks in advance!
Can you attach the code please.
To: Post your G-code File
If you have a Standard Install of Mach you'll find the File in C:\Mach3\Gcode folder.
Use the "REPLY" Button then Attachment Options, "Browse" to C:\Mach3\Gcode and find the file, Double click on it and Post.
Hope this Helps, Chip
it's a simple newbie cut!
Seems to work fine here, can you take a screenshot to show what you are seeing for the toolpath.
Found the problem!!!!
Beware of windows installer 3.1 [ kb893803]
When instaled, disable the driver of mach 3 cause it will cease it.
thanks
