Mach Discussion => General Mach Discussion => Topic started by: modnet on February 28, 2008, 06:27:08 PM
Title: Spindle setup - help
Post by: modnet on February 28, 2008, 06:27:08 PM
Hi -
I have a mill conversion on the go -
What is the preferred interface for the spindle speed control ? (step/dir or pwm)
It has a servo motor on the spindle - does anyone know if I can drive this with a gecko servo drive (or will it not go fast enough) ?
The servo is about 60volts and 500 step rev encoder
And what is the max number of steps a second that mach3 might do ?
Best regards
Dom @ Australia
Title: Re: Spindle setup - help
Post by: Hood on February 28, 2008, 07:04:15 PM
Mach can do safely 45KHz per axis (some guys can get as much as 100KHz and more, depends on computer/port etc) so thats 45,000 steps per second. With your 500 encoder thats 2000 per rev. 45,000 /2000 =22.5 Revs per second =1350RPM.
 I am thinking of doing this on the mill I am retrofitting at the moment, I have a 5KW AC Servo but I will be using the smoothstepper for this machine and that means I have a max pulse of 4MHz, my encoder is 2000 line (8000 as far as Mach is concerned) so I could spin my motor at 30,000RPM if it would do it without flying into ten million bits LOL. 4000 is its max so I have plenty of headroom. :)
