G-Code, CAD, and CAM => G-Code, CAD, and CAM discussions => Topic started by: accramachine on May 03, 2006, 10:59:18 PM
Title: regarding z axis jog while running
Post by: accramachine on May 03, 2006, 10:59:18 PM
Hi all,
Can anyone tell me how to make mach3 jog the z axis while the program is running. I have tried check marking the box "allow THC up/down control even if not in THC mode" found on the mill setting page. But I still can only run the z axis up and down when the program is setting idle? Thank you in advance!
regards, John S. Wracher
Title: Re: regarding z axis jog while running
Post by: Brian Barker on May 04, 2006, 05:53:00 AM
There is a THC active that needs to be active as well. It is on the ports and pins page under the inputs.
To jog the Z in a program you need to use THC up and THC down under the inputs...
Post by: accramachine on May 04, 2006, 05:50:40 PM
Thank you Barker! I did what you said and that fixed the problem. Thanks again! Maybe someday I can return the favor.
John S. Wracher
Post by: Brian Barker on May 04, 2006, 05:57:47 PM
Small unmarked bills ;)
Post by: rayhager7 on April 07, 2007, 11:53:48 AM
I'm also trying to jog the z axis while Mach3 is running. I'm also using the THC from Campbell Designs. I've tried setting hot keys and they act just like the regular jog keys... Help???
Post by: Chaoticone on April 07, 2007, 12:15:06 PM
Hey Ray,
    I have sent you a personal message.
Post by: Chaoticone on April 07, 2007, 12:24:24 PM
also, do these help?
Post by: rayhager7 on April 08, 2007, 11:30:03 AM
Brett,
One step forward but still not working as needed...
It turns out you were right about using keys that were already assigned to something else. Once I found a couple of unused keys [ and ] and set them up it appeared to be working... while running a program I could jog the Z axis but then Mach ignored the THC! It wouldn't respond to height correction signals until I disabled the hotkey emulation....
Any other ideas?
Hope you are having a nice holiday weekend,
Ray
Post by: Brian Barker on April 08, 2007, 05:35:00 PM
The Only way that you can have both is to  hook your "override" buttons up in parallel to the inputs for the THC. That should work...
Post by: rayhager7 on April 08, 2007, 06:23:49 PM
Brian,
Yes that sounds like what I need but I'm not sure exactly how to do that...  :-\
Do you mean to set up buttons to toggle two of the output lines and physically connect them to the THC up/down input lines? Or, is there another way?
Hope you're having a nice holiday weekend,
Ray
Post by: Brian Barker on April 09, 2007, 06:11:01 AM
Yes, you will need to connect them to the two phisical THC Up/Dn Lines.
Please contact the maker of your THC unit for help with this :)
Brian
