Mach Discussion => General Mach Discussion => Topic started by: jpeter on May 03, 2006, 05:52:13 PM
Where's the switch to activate "allow block delete"
Jim
the LED needs to be on to get it to work...
How easy can it be. How could I have overlooked something so obvious. I've yet to check my machine though. No doubt the switch will be there.
no problem, I do the same thing :o
Ok, so what do you do with Block Delete?
If you are running parts that may need to have an extra pass to You can add the code with a "/" at the start of the block. As you can see in this example you could add a face pass...
G00 Z1.0
G00 X0.0 Y0.0
/G01 Z0.0 F30
/X5.0
/G00 Z1.00
/X0.0
G01 Z-.1 F30
