Mach Discussion => General Mach Discussion => Topic started by: 3FAB on May 02, 2006, 06:13:35 PM
Title: Feed Rate Errors
Post by: 3FAB on May 02, 2006, 06:13:35 PM
Mach 2 will radius an angle cut when the feed rate is to high on our plasma cutter. How do I prevent this from happening without slowing the feed rate down? Does Mach 3 have this same problem?
Title: Re: Feed Rate Errors
Post by: Brian Barker on May 02, 2006, 07:06:34 PM
That is the CV (G64) try putting it in Exact stop (G61)
