Mach Discussion => General Mach Discussion => Topic started by: Anthony on February 19, 2008, 12:32:04 PM
Can you say me how to use sensors in Mach3 ? I want to use sensors in a GCode.
Can you explain a bit further what you mean by sensors?
When I say "sensors" it mean a sensor that I have to support it to run the machine, I want to use a sensor which looks like a button.
sorry Anthony, you have lost me, hopefully someone else will understand what you are wanting and will be able to help you out.
Hi all!
Anthony, do you mean a solid state sensor used as a limit switch?
olf20
Or do you mean a failsafe switch - where you have to hold the switch down (or up) to make the machine work ???
