Mach Discussion => Video P*r*o*b*i*n*g => Topic started by: mhasting2004 on February 18, 2008, 08:15:49 PM
Title: Functionality idea
Post by: mhasting2004 on February 18, 2008, 08:15:49 PM
Hi Guys
I've been watching this and other threads with great interest (now I really need to get my machine finished).
I had a bit of an idea last night which you may or may not have thought of as a functionality / feature for you plug in.
If you can set a pixel position of the laser line once you set tool height and save this as a tool offset you have a non contact material height sensor.
If you add edge detection you can find the material X,Y (0,0)
For the edge detection I would think you would want 2 laser lines at 90 degrees to each other or possibly a single one at 45 degrees to the workpiece. In the first instance (2 lasers) you would look for a drop in height of each, in the later (single beam), the line will get shorter and shorter until it drops off.
What ya think?
Mark
