Mach Discussion => General Mach Discussion => Topic started by: Hugo Carradini on February 18, 2008, 07:47:27 PM
Hello guys. I need help to fix a problem i have when i tried to run a program that have a pentagon or a triangle in the design. It looks OK in the cam program and runs nicely but when I take it to Mach it wont show it correctly in the screen and when I run the program the cut is wrong like in the screen. Is there somethin I have to fix in Mach3. Something that is happening lately is that when I make a design and run it in my cam program every thing runs OK but when I take it to Mach some times one or two lines wont show correctly. I guess it is connected to the pentagon and triangle problem. Thanks for the help
Please attach a sample of your code and it might also be worth attaching your xml as well.
Hello Hood. I tried to attach the archives but allways get the same answer "There is already an attachment with the same filename as the one you tried to upload. Please rename the file and try again" I don't understand what to do. Sorry for my poor internet handling.
No problem Hugo, just rename your file before you try to attach it.
Sorry for not answering before. All the problem was in the CAM program. Mach still the leader and a great program.
