Mach Discussion => General Mach Discussion => Topic started by: jhewitt123 on February 17, 2008, 12:25:12 PM
Hi, I got no response as yet from other groups so I wanted to ask again here. My ncpod wroks fine under ncpod software. I have installed the plug-ins for Mach3, and get an ncpod box to check on startup of mach3. Why do I not get a USB box to check under the ports and pins config but still get just the maxnc box. How to I then get Mach3 to do anything with my pod?
John Hewitt
jhewitt123@comcast.net
Not familiar with the ncPod but I think possibly you will maybe have to look under the plugins menu and config the ncPods basic settings from there, maybe you will still set up in ports and pins as normal or it may all be contained within the PlugIn. If this doesnt help then maybe post this in the part of this forum which is specifically for the ncPod.
