Mach Discussion => General Mach Discussion => Topic started by: Keith on April 28, 2006, 12:34:44 PM
Title: Pins and Jogging
Post by: Keith on April 28, 2006, 12:34:44 PM
Hi,I know it's possibelt to use the pins to control jogging; is there a way to use a pin to change the jog mode('continuous' versus 'step')?
Also,is there a way to use the alloted input pins for such things as this and other things like limit switches ,in a binary mode so 5 inputs could become 32?-Keith
Title: Re: Pins and Jogging
Post by: Brian Barker on April 28, 2006, 06:48:05 PM
There is a way to make the cycle the jog types and you are going to have to use an input pin and a macropump...
There is no way to use the pins the way you were thinking... Sorry
Post by: Keith on April 28, 2006, 07:00:11 PM
Hmmm,so that means VB ,right? Homework... : (
Post by: Brian Barker on April 29, 2006, 06:11:07 AM
There is also a way to do that with an OEM input that triggers a Macro... I have done that one time (I think), so if you et stuck I am here to help.
