Mach Discussion => General Mach Discussion => Topic started by: catch22 on February 02, 2008, 08:36:58 PM
How come Mach3 has reverted back to Mach3 R2.63 it was at Mach3 R3.00 just a little while ago is there problems with it or something?
Thanks Mike
Hi, Mike
Hears a couple comments Brian made.
Hello ,
I have taken 3.00 off the web... this version had a change that would
make files run MUCH faster BUT this is raising hell in Mach3...
The new 3.03xx revs seem to be testing well but there is still much more
Dev work that needs to be done..
If you are running 3.00 and you do not see a problem... I would run it,
it makes a much better drill cycle :) You will only have a problem with
that Rev if you are running brains and so on...
Brian
Thanks, Chip
