Mach Discussion => General Mach Discussion => Topic started by: lemo on February 02, 2008, 10:17:17 AM
Hi all
I am looking for a list of all the alt and ctrl key combo's build into mach3. Recently I am fumbling on the keyboard resulting in anything from scary to comical results as Mach3 does 'something' I did not expect. I also reached a really nice and cool jog screen, which I could not reach again as the keycode is eluding me.
I took a look at the documentation and that doe snot contain a full list, but the instructions on how to set a code up if you choose to do so.
A little help in locating the master list would be greatly appreciated!
Cheers and a great weekend!
Rainer
Jog screen is the Tab key.
The hotkeys are listed as their ASCII number in the customisation manual I think, they are definitely in one of the manual and I am almost positive its that one.
Thanks! Tab... dohhhh. Did not find that. Maybe a quick ref card should be put together with the basic tricks.
When I'm a bit more in control I shall make one.
Thanks!
Rainer
