Mach Discussion => General Mach Discussion => Topic started by: giordano on April 27, 2006, 07:29:36 AM
Hi to all. Since I had any losses of step, I have reduced the acceleration of the 10-20s motors mm s/s. As in the figure.
In this way the execution of a circle is not uniform anymore, but to hiccup. There is a cure. Thanks in advance, Giordano
You have to Retune your axis after you change your Khz mode. Sorry
