Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: davew on January 23, 2008, 08:48:50 PM
I have just been introduced to the Mach3 software and am looking for ways of automating it from external software.
In skimming over the manual, I noticed in section 3.1.3, it states that using the OCX it is possible to control Mach3 without its GUI. Where can I find more information on this?
After a few hours of digging around I've come across talk about Plugins, but can't find any "Getting Started" documentation (other than how to setup Visual Studio). At first impression, "plugin" sounds like something used WITHIN Mach3 (and it's GUI), rather than something to control it externally.
Any good pointers on where to start? I'm comfortable with most any development language/environment.
Any assistance greatly appreciated,
Dave,
Have You looked at the Mach3 SDK about half way down the downloads page? It may help.
Kenny
Hi, look at the version 2.0 programmer information on this page:
http://www.machsupport.com/artsoft/downloads/downloads.htm
Mach3 has an Automation Object Model that can be used to control it externally. My plugin tutorial and sample file set also show how to use this from inside a plugin. There is a 'RemoteControl' application download on the downloads page that shows how to use the object model from a C++ program (for VC++ 2003).
-James Leonard
Thanks guys. I guess I was looking mainly at the menus of the website and not drilling down into each page enough.
I've got both VS2005 & VS2003, so I'll give it a look.
You are welcome!
Get the latest Mach3, it has an embedded typelib. Then just point VS2003 at it and do a create class from typelib. You can then see all the automation methods. Only a plugin has access to Mach3's internal data blocks directly.
The VBscript docs and some searches on macros will give you a good start on what the object methods can be used for.
-James Leonard
Ok, I've got my hands dirty and I'm back with a few questions...
First, thanks James for your Plugin tutorial and whoever wrote MachRemote.
I've developed an application in C# (VS2005) and have been tasked with making it automate Mach3.
What I've done is created a DLL which exports many of the functions of the Mach3.exe Object Model. I used James' Plugin Tutorial as a reference to get started. I then imported these functions into C# and wrapped them with a C# class (which handles connection, exceptions, etc).
This isn't a plugin. I'm not doing anything with dialogs. I'm just setting DRO's, pushing buttons, etc.
So far it is working well except for when I shutdown my app and restart it. After the first time I run, future runs of my app fail to connect to Mach3. If I shutdown Mach3 and restart it, everything is fine (until I shutdown my app and restart it).
I've added some debug code and discovered subsequent runs are failing with a result code (HRESULT) of 1 from GetActiveObject(clsid,NULL,&lpUnk) (see Mach3ObjectModelStartup() in Plugin Tutorial; page 73/92 in V01).
So I started by looking at the shutdown code where I detach from Mach3. In the plugin tutorial, it appears to only be calling "CoUninitialize();" (see Mach3ObjectModelShutdown(VOID); page 74/92 in V01).
However, in MachRemote, I find this code in CMachRemoteDlg::OnBnClickedDisconnect():
scripter.DetachDispatch(); //detach the scripter object
//mach4.ShutDown(); //then shutdown MAch3's interface..
With only the CoUninitialize() call in Plugin Tutorial, Mach 3 would complain on exit with an Art Code of 9991. After I added the scripter.DetachDispatch(), this complaint went away (mostly at least). If I add the "mach4.ShutDown()", this creates an additional error.
Any insights on what I'm missing?
Why doesn't the Plugin Tutorial call scripter.DetachDispatch()? (oversight? am I missing something?)
Why is mach4.ShutDown() commented out in MachRemote?
Any insights appreciated,
Hi Dave,
It is the difference in the process models I believe. The Mach3 plugins run in-process to Mach3 so it is too late for me to detach the dispatch interface at the point the plugin shutdown code gets called (I got a crash myself for trying it...).
The scripter.detach() call should return the IDispatch pointer, so try releasing it as so:
IDispatch tmp = scripter.detach;
tmp->Release();
-James
tmp->Release();
James,
Here's the shutdown code I ended up with, based on your suggestion:
LPDISPATCH tmp = scripter.DetachDispatch(); //detach the scripter object
tmp->Release();
// mach4.ShutDown();
CoUninitialize();
Unfortunately this didn't appear to help. I'm stilling getting HRESULT of 1 from GetActiveObject on my subsequent runs.
Dave, I am totally clueless as to C#, but in VB (6) setting the object to Nothing would release all references. It looks like you are somehow still holding a reference to Mach3.
Since you have your code in a DLL you should be sure the DLL is unloading also. If not, maybe you have a persistant state in the DLL?
-James
Figured it out...
I was just digging around CMach4.h and realized the ShutDown() call is to close the Mach3 app. ...not what I was trying to accomplish.
After a bit more digging, I noticed we're doing an AttachDispatch for both mach4 and scripter...but only doing the DetachDispatch for scripter.
This code is working for me well now:
mach4.DetachDispatch();
CoUninitialize();
Thanks for your thoughts/time on a Saturday afternoon!
You are welcome. Since I run as a plugin I am not concerned with Mach3 lifetime control.
I'm glad you were able to get this running.
-James
Hi Guys,
I am working on remoting mach from C# as well. I have got most things working, but I am tearing my hair out with a problem. Brian added into Mach3 the .GetMessage call (to display the status label data), this returns a BSTR, now that is well and good in C++ but it is killing me with C#. Do you guys know of a way of accessing a BSTR in C#???
Andrew
Hi Guys,
Andrew
I really don't know .NET at all, but I believe that you need to write a COM Interop for the Mach object model
Andrew,
I haven't needed strings yet, but as I was getting started, the following article was helpful for me.
http://msdn2.microsoft.com/en-us/magazine/cc301501.aspx
Not sure if this would be any help to anyone, but here is a rough test application I was using to get the hang of remoting Mach3 from C#. I can't post the finished code as it is for a customer, and I don't think he would like me posting it here.
Any questions or suggestions please give me a yell.
Regards
Andrew
hi,
can we do this in VB.NET ?
regards
carlo
Hi Carlo
Sorry for not replying sooner, but I have been away.
Yes you can do this with VB.net. I have only just started using C#, I used to use vb.net for everything, but I am now a convert and use C#.
If you would like to use INSTANT VB (tangiblesoftwaresolutions.com), my C# example should convert to VB ok - I havn't tried this, but I have used this converter software in the past and it seems to work perfectly from C# to VB but a little dodgy from VB to C#.
Hope this helps
Andrew
thanks Andrew,
I'll see what i can do.
i've never used the SDK untill now so i have a couple of questions befor starting.
* When we use VB.NET and Mach SDK, does it mean we can run MACH3 without acually running MACH3 standard application?
* When I run the test C#, on the screen ther is the load button, when i load the MACH from the test screen the standard Mach is running on the backround and displayed within the screen, I don't understand why to run a screen like test C# when you have the same screen running on the backround.
i hope you understand my point ::) :-\
