Mach Discussion => General Mach Discussion => Topic started by: tivoi on January 18, 2008, 11:29:51 PM
How to setting mach 3 control spindle just on and off? thanks for your help
Hi tivoi
config / ports & pins / outputs - choose an output pin. e.g. 1
config / ports & pins / Spindle setup - Clockwise M3 output # - set to 1
wire pin 1 to your relay control
you can now turn on with M3 and off with M5.
thanks stirling, i'll try.
thanks again
