Mach Discussion => General Mach Discussion => Topic started by: corydoras on January 17, 2008, 03:27:09 PM
Title: Assigning output for dust skirt
Post by: corydoras on January 17, 2008, 03:27:09 PM
I have mounted a pneumatic dust skirt that I want to control via an output in mach3 ,when I start the cycle, and return after end program
I am running the solenoid throu a PLC, and only need info on how to assign/configure the output
Didnt seem to find any info on this when I watched the input/output video here on the site
Thanx in advance
Best reg
Cory
Title: Re: Assigning output for dust skirt
Post by: Hood on January 17, 2008, 04:55:30 PM
Not sure I understand but if its just the pin and port address you need then it will be whatever output it is on your PLC and the port will be 0. Example I have an OEM trigger input set up as Port 0 and Pin 16, this is because its Input 16 on my PLC.
Post by: corydoras on January 17, 2008, 11:25:27 PM
Ok, mabye a little confusing, how do I configure an output to be on during cycle run only?
(the output triggers a 5vdc relay that gives 24vdc on my plc input that again operates the solenoid)
in other words:is it possible to configure selected output pins in ports and pins to do what I want during mach operation?:)
best reg
Cory
Post by: Hood on January 18, 2008, 01:02:55 AM
Cory
 that should be easy enough to do if you use a Brain. Just write a Brain to look for example the Run LED and when its on to do the Output you want.
Post by: Chip on January 18, 2008, 08:33:05 AM
Hi Cory
In Ports & Pins, Spindle Setup, M3 turns spindle ON, Output 2, You could use it to turn on both spindle & Dust Skirt, M5 at end of G-code will turn them off.
Then in Ports & Pins, Outputs, assign Output# 2,  Printer Port it's Port 1, Pin's 2-9, 1, 14, 16, 17 to standalone plc input.
For ModBus it's Port 0, then use Brains.
Look at modbus and braines section for examples.
Maybe a starting point, Not sure which way you want to go.
Hope this Helps, Chip
Post by: corydoras on January 18, 2008, 09:09:58 AM
Thanx guys, the brain writing was a blast, I´ll be using this for many many operations.....never knew it existed......thats the best part of this forum and Mach3 , always something to learn, everyday.
Youre right chip, actually started thinking of this as I was writing a brain, I have now done it this way, less wiring, and it saves an output on the printer port
Ill post some pictures/video of the pneumatic dust skirt in action
Best reg
Cory
