Mach Discussion => General Mach Discussion => Topic started by: abomb55076 on April 24, 2006, 10:07:22 PM
I have a maxnc 10 or 15 I think and I wanted to use mach 2 or 3. When I try to use the maxnc mode or watever it doesnt seem to work and i dont know how to set up the pins or anything either. I have no idea wats wrong. I think my port is right. i have it set at 0x378 or something close to that and thats what it said on the video tutorial. Please help!! ???
IM confused!!
Are you looking for the pinout? What point are you at?
I was wanting to use that maxnc mode but i dont know if that works with mine or not. I dont have anything input anymore because nothing i tried worked so im starting at the beginning
I am just starting with my maxnc also.
When the mach3 program was runing the motors were energised ( the handwheels were stiff)
My problem was the estop. I went into the config screen and changed the default setting for active hi/lo.
Try reading through all this stuff about Max nc. I know others have used it and it has worked for them.
You would have found links to this stuff if you had read the other posts I suggested b4.
See the attached folder
no i have the motors turning but i have two motors running off the x for some reason and one off the z and when i press the y it like disabbles all the motors untill i get the y into a certain position then the motors get back to moving. Also i have encoders...
If you have encoders on your MaxNC you need to use the Max CL Mode enabled setting. It sounds like you are using the Max NC-10 Wave Drive setting. It has four signal wires per motor and your setup only uses two (that is why two motors are moving together.).
Darek
but when i have it set in maxnc cl mode I couldnt get them to move at all.....
If you are trying to jog with the #pad make sure NumLK is off.
Darek
im jogging with the regular pointer arrow thingys
do you have a msn or aim screen name?
If you are getting it to reset you need to look at the diagnostics screen (lower right) and see if jog is on and jog mode is continuous.
Darek
it moves the numbers , like the coordinates or watever but it doesnt move the motors or anything. do you have a msn or aim???
Make sure you have your port set to the same setting in CL mode that moved the motors in wave mode. If you do and it still does not move then you need some way to test the pins of the printer port for activity. I included a sample off a simple tester.
Sorry no MSN or AIM
Darek
is there anything else i can do, i dont have the little resister or whatever to put on a led to test my pins. Also just to remind you i have encoders and i was woundering if you have to setup the pins and ports for those even though you dont have to set them up for the motors (because of the maxnc mode)
When you are in MaxNC CL mode you have 2 output signals for each motor X,Y,Z & A. There is one input signal that goes back to indicate servo OK (These pins and functions are all preselected when in the MaxNC CL mode.). The encoder feedback is all handled in the MaxNC electronics. There are parameters that are set in the MaxNC controller with their sofware. Have you had it running with there software satisfactory?
You can usually use just the LED for a quick test.
Here is a link for the MaxNC CL mode pinout.
http://machsupport.com/forum/index.php?topic=202.0
Darek
actually i recieved this from my uncle and he lost the software so we called and they said they would send us the software but when they did i guess they didnt send us all of the software.
MaxNC software for that machine when installed should make a file on your C:/ drive named MAXNC_S. If it is Plain MAXNC with no _S it is the wrong software. The .DAT files in the correct software contain the parameters and are loaded at the beginning of each session is my understanding.
Darek
ya i dont have that......anything else i can do??
ok so i put an led into the pins 5 and 4 on which are the y axis and when i tapped the jogg buttons it turned the light on and then it when off after i pushed it but then sometimes it would stay on untill i tapped it again. So i think my ports are all working and everything but im not sure why my motors arnt moving. Also, theres a pic of my motors and controller just incase.
You have Mach setup right then. That is a CL system probably a 10. To go any farther with that controller you need to get your hands on the Max sofware and get it running with it first then turn it over to mach.
Darek
