Mach Discussion => General Mach Discussion => Topic started by: sooperdrave on January 14, 2008, 06:12:02 AM
Title: a axis wont reference
Post by: sooperdrave on January 14, 2008, 06:12:02 AM
my machine is a 5 axis machine with x, y, z, and a axis'  my a axis is a rotating table.  it wont reference.  when i try the status line says:  "requested home axis home switch is active.  please fix, then home."  anyone know what this means or how to fix it?
thanks,
dave
edit:  also the homin g switch under the table is on and not turning off, wondering if the switch is junk?
Title: Re: a axis wont reference
Post by: Chip on January 14, 2008, 12:51:04 PM
Hi, Dave
Check the switch out, Then in ports & pins, inputs, You may need to change the "Active Low" setting state for the A axis.
Chip
Post by: sooperdrave on January 17, 2008, 06:25:07 AM
hi chip thanks for helping!  i tried turning changing active low.  when i did the light on the switch and in diagnostics turned off.  then i tried to reference and it still didnt work so i put the settings back to what they were.  i think the switch is just junk.
thanks
dave
