Mach Discussion => General Mach Discussion => Topic started by: robotix on January 12, 2008, 08:18:53 PM
I am just learning this system so bear with me. My Mach3 mill v2.58 does not pause, home or otherwise notice that there is an M6 in the code. I read the manual and it says to make sure that tool change is enabled in config>logic. Problem is, there is no config>logic on my pull down. Can some explain to me what I am doing wrong and what I need to do to get the machine to pause for a tool change, and then return and continue. Also, any guidance on how to insure the Z axis is calibrated after a tool change would be appreciated.
Jim
Config-> Logic is now just [pull down menu] Config --> General Config.
