Third party software and hardware support forums. => Third party software and hardware support forums. => Topic started by: corydoras on January 11, 2008, 05:18:23 PM
Title: New BOB, what do I choose
Post by: corydoras on January 11, 2008, 05:18:23 PM
Hi guys
I need a breakoutboard for my second paralell port to make the buttons on my controlpanel connect to my computer.
Do I need a seperate BOB, or can I use the +5v on the other bob as long as i connect the grd´s, or  is there a common ground in the pc that takes care of this?
Of course this would not be isolated in anyway, but can it be done?
I run a secondary paralellport driving 2 servos in step/dir, and a driver/bob for the stepper on the z axis.
This bob only have homing, limit/emergency input and 3 outputs.
Running my machine today wit just an old printercable stripped at the end and the wires connected directly, but as I understand I need a BOB to get my 5v from the specific paralell port , as i dont see any +5v on the paralell port pinout.
I guess the 5v on the other port/bob is transformed from the powersupply on the board, am I correct+
So need a tip of what BOB to get to make this good, easy fast and cheap....hmmmm possible?... dont know, but the fast part could be nice:)
Bring it on guys, what do you recomed for a BOB intended only for I/O
Live in Europe so if anyone have any suppliers ther it is also interesting
Best reg
Cory
Title: Re: New BOB, what do I choose
Post by: Graham Waterworth on January 13, 2008, 05:24:15 AM
I used this one for my second port, just have buttons and a mpg connected to it.
http://www.routoutcnc.co.uk/quickconnect.htm
Graham.
Post by: corydoras on January 13, 2008, 02:41:48 PM
Thanx Graham
Just what I was looking for
But for now i have just stripped the printercable and connected them to terminal blocks in the electrical cabinet.
Played around a little with the wires and found out that i did not need a +5v, kust connected the input wire/pin to ground and then I got the signal.
Is this the way to do it?
BTW what does the emulate function do in the ports and pin setup of inputs?
Best reg
Cory
