Mach Discussion => Mach SDK plugin questions and answers. => Topic started by: Rallymax on January 11, 2008, 12:17:17 PM
Hi all,
I'm excited to be joining the Mach 3 world :)
I'm setting up a 4 axis mill and have three controllers.
X,Y are to be run by a Parker 6250 controller running Parker SM servo motors
Z & A are to be run by Parker iBE self-contained servos
I've started with the SDK (which is GREAT!) and have the basics done for the Parker6250 controller (using a serial connection) but I also need to communicate to the serial port of each of the iBE servos.
My question is this: Can I have MULTIPLE plugins active at the same time assigned to different axis?
If not, I'll have to make a 'special case' dll which happens to control both - I'd rather give the dll's back to the community for general use though.
The other alternative if for me to make a MultiplexMovement.dll which then pulls in other plugins to allow the assignment of axis to different controllers.
thanks
Edward.
This may be the answer to your question - Check Yahoo message 82997 from Art. There were some other messages there about the serial port.
Hope that helps.
Lee
