G-Code, CAD, and CAM => LazyCam (Beta) => Topic started by: Noto on January 06, 2008, 11:16:21 PM
I have tried with a number of files and can't get it to post the code.
Says it does but no file appears :(
Here is one of the files I am trying.
I,m no expert so I'll tell you everything I know. In lazycam click "setup" then "Posting options" then as below. Good luck, Ben
Thanks Ben, thats exactly what I have done and no luck at all.
It says it does it but nothing ever gets posted or any file created.
I drew a curve using Bezier lines and LC wouldn't produce a gcode file. I did the same using a polyline and it worked fine. So redraw your DXF file and see if that works. Ben
Hi, Noto
I tried your file, It, posted ok with and with ought a LC Pro Lic.
Try re-downloading LC again, Hears a post of it.
Thanks, Chip
What does it say in your gcode file option?
Brett, It looks exactly like Bens screenshot.
I have sent you a personal message.
Replied :)
