Mach Discussion => Mach Screens => Finished Screens => Topic started by: poppabear on December 24, 2007, 09:10:48 AM
Title: Quick Threads Wizards
Post by: poppabear on December 24, 2007, 09:10:48 AM
Here is the Re-uploaded "Quick Threads" Wizard, (
I  built a Lathe Threading Wizard called "Quick Threads", you can do Multiple threads, clearances, directions, hands...etc.
I added that nice little "Free Ware" Thread calculation Wizard that was posted up here so You can have an easy access Thread form calculator chart!! It has a Help file for how to use it, please read the "Read Me 1st".
I hope you like it, tell me what you think,
Scott S.
Title: Re: Quick Threads Wizards
Post by: fisherjim on January 04, 2008, 05:35:34 PM
Well I like it.
 I don't suppose  it's possible to do a wizard for roughing and finishing a profile, in diameter mode, plus a thread, is it............... please?   ;D
Jim..
Post by: poppabear on January 04, 2008, 06:56:56 PM
There already are some roughing/finishing wizards for just that, run one of them first then run the threader.
scott
Post by: poppabear on January 12, 2008, 04:35:40 PM
here is an updated screen set, with more muted colors, by request. also bug fixes for metric posting.
scott
Post by: Segrest on February 26, 2008, 08:10:26 PM
Hi Scott,
I'm just getting started with cnc threading and your new wizard seems like a good starting point.
One dumb question to start with...  How do I change a value on one of the wizard screens?  If I highlight a field, I can change the value, but as soon as I select another field the value reverts to it's default.  I'm doing something silly, please enlighten me...
When I load the wizard the field values are displayed in a yellow font on a bright green background.  Its kind of difficult to read.  Is there an easy way to change this?
Bob
Post by: Segrest on February 26, 2008, 08:13:09 PM
Hi Scott,
It looks like I pulled down v2 with the non-muted colors.  I'll pull down V3 and try again.
Still haven't figured out the change settings silliness...
Bob
Post by: Ron Ginger on February 26, 2008, 08:20:20 PM
I wish I had a buck for every time that problem has appeared here. After you enter a value you must press the ENTER key, if you click into another box mach assume you really didnt mean to change the value.
Post by: hlombard on April 09, 2009, 10:47:32 PM
Where do I copy this .set file to make it work?
Post by: Ron Ginger on April 10, 2009, 07:22:29 AM
If you want it to appear as a turn  wizard then it goes into the c:\Mach3\TurnAddons\QuickThreads. It will then appear on the list of wizards shown by the menu item for wizards.
Post by: poppabear on April 10, 2009, 07:48:46 AM
Thanks Ron, for answering that, appreciate you my friend!
scott
Post by: Newlathe on January 16, 2022, 05:34:55 PM
Hi! Is any tutorial video avaible in YouTube or another site? I don't find it
Regards
Post by: bob.landess on February 20, 2023, 02:12:22 PM
How do I use MDI and motor tuning with this screenset?
