Mach Discussion => General Mach Discussion => Topic started by: cfm on November 22, 2005, 08:35:18 PM
I can't seem to adjust the height at which the plasma cutter is, moving it left/right or up/down is fine, but i need to lower it a bit, and can't seem to do it.
can anyone help?
thanks
There are a few ways to move the plasma up and down. IF it is when it is cutting you can use the torch up / down inputs. OR if you just need to move it and it is set up as the Z axis you can use PGUP and PgDn.
Very sorry if that is not what you are looking for
Hope that Helps
Brian
