Mach Discussion => VB and the development of wizards => Topic started by: saleh on December 17, 2007, 12:01:58 PM
I have Mach3 and I need help for Tool changer .for Mach3 lathe.
for example if I use in my micro.
tool = GetSelectedTool()
if tool = 1 then Activatesignal(output1)
else
Activatesignal(output2)
deactivatesignal(output1)
end if
this will work only Mach3mill .I tried it with mach3lathe never work.
Please if any body can help me .So I can use it to mach3lathe.
saleh
I think that should work. How are you calling the tool in Turn? Instead of M6T1 you would just put T0101
t0101 = Tool 1 offset 1 so T1002 tool 10 offset 2
thank you Hood,
I tried it and your way work fine
saleh
