Mach Discussion => General Mach Discussion => Topic started by: tbriggs on December 11, 2007, 10:03:01 AM
I installed Mach3 and on the "Settings" screen the background is green. All the other screens are grey.
How can I change that or is my 1024.set bad?
Thanks!
tbriggd
I think thats the standard screen, you could use Screen4 to delete the backgound image on that page and you would end up with the grey background. However there wouldnt be any borders seperating the sections on that page.
You will find screen4 in your Mach folder, and all you do is open the screenset and once opened click on the Settings tab. You will then be at the settings page and if you click on the green background you should see that it has been selected, you can then press delete on your keyboard and the background image should go. I would suggest you keep a backup of the standard screen either that or make sure when you exit Screen4 you save your modified screen as something else. It is actually better to choose to rename it as if you upgrade Mach your modified screen wont be overwritten.
