Mach Discussion => Mach3 under Vista => Topic started by: StevenDAntonio on November 24, 2026, 09:46:19 PM
Title: Strange behavior of Autozero
Post by: StevenDAntonio on November 24, 2026, 09:46:19 PM
I have been using Mach3 on windows 95 very happily for many years. The last 2 times I have used it the Autozero (which has been working perfectly for years).
The normal behavior should be, The bit advances to the touch plate, touches, stops, moves up to z=1.000
The current behavior is, The bit advances to the touch plate, touches, stops, and does mot move off the touch plate. Additionally after this I can not jog the bit until I hit the reset button twice.
I have not dug into the script yet to see if anything changed in it ( can't think why it should change), but before I do that it's probably easier to ask if anyone has seen this behavior before. Maybe I accidentally hit a switch in the software or something.
Thanks Steven
