Third party software and hardware support forums. => PoKeys => Topic started by: Holzwurm56 on September 02, 2026, 04:03:30 PM
Title: Need Help with MPGs?
Post by: Holzwurm56 on September 02, 2026, 04:03:30 PM
Hello,
I want to install a new control system on my lathe. I am using Windows XP, Mach3, and a PoKeys57E. I wanted to connect the handwheels now. I connected the first one to I/O pins 1 and 2; it is recognized in Mach3 Diagnostics and counts up and down correctly.
I connected the second MPG in the same way, but it isn't being recognized by Mach3. I used an oscilloscope to verify that the MPG is working. I also tried connecting it to different pins,
but it still doesn't work. Does anyone have any ideas?
Hans
Title: Re: Need Help with MPGs?
Post by: Holzwurm56 on September 03, 2026, 05:12:28 AM
In the setup from the PoKeys57E both MPGs are working, both count up and down. In the diagnostics from Mach3 works
only MPG 101.
