Mach Discussion => FAQs => Topic started by: texasmaker on November 23, 2007, 10:26:02 AM
Hello,
Does anyone know how to change the font size on the Mach 3 screens? I'm using XP. I've been to the font menu under the config menu but I can't make the changes stick?? Several of the labels in the main screen and most of the wizards are cut off. Thanks.
I just put the licensed version on my CNC computer last night. I have the same problem, my labels are cut off both length and height wise. I can read most of them, but I still would like to fix it. Using the Fonts on the text menu, I change the size and type of the font, but when I close the screen it does not stay.
I also noticed in my Thread Mill wizard, when I enter numbers, as soon as I go to the next field the numbers change back.
I have double checked on the about tab and it shows my name in the Licensed To window.
Could anyone shed some light on what I may be doing incorrectly?
When ever you enter a number in a DRO you have to press ENTER to confirm it.
Have you got auto scaling of screen set in the general config, this can some times mess the fonts up.
Graham.
Before closing Mach, go to operator, save current layout.
Thanks, Brian helped with the DRO. I did go and set the auto scaling and that fixed the cutoff labels.
Thanks for the help.
