Mach Discussion => General Mach Discussion => Topic started by: Green4020 on December 14, 2025, 03:51:30 PM
Title: Trouble getting Bridgeport Series 1 CNC to work with new computer.
Post by: Green4020 on December 14, 2025, 03:51:30 PM
I have a Bridgeport Series 1 CNC that still has the old motor controls that was run through Mach 3 using the printer port.  My motherboard died on the old computer and I have been trying to get it going on a newer computer.  The new computer has Windows 10 32bit on it so I had to get a UC100 motion controller to run it.  Once it the driver was all installed correctly, all I am able to do is get the motors to make a high pitched whining sound but no movement out of all three travel motors.  I was able to get my old hard drive mounted in a case to be able to pull the old settings to the new computer but still no luck.  There must be something wired a bit differently from the old printer port to the UC100.
I know switching this mill over to newer motor controllers would be best in the long run but I was hoping to learn more about cnc milling before spending more money and time on the old machine.  I'm new to most of this and figuring it out as I go when I find time.
Thanks for any help.
Title: Re: Trouble getting Bridgeport Series 1 CNC to work with new computer.
Post by: JohnHaine on December 14, 2025, 11:59:08 PM
You may have the step rate set to high for the motors and/or drivers. We're you able to rescue the xml file fro the old controller?  I use 2 uc100s for my lathe and mill and they work fine. You could also ask over on the cncdrive forum as they make the uc100..
Post by: Green4020 on December 15, 2025, 02:43:42 AM
Yes, I was able to use the xml file from the last computer.  Ive messed with the step rates some but nothing seems to change.
Post by: arturod on December 16, 2025, 10:11:25 AM
Mach3 cannot delegate real-time motion control to two motion controllers at the same time.  For a Bridgport, get something more robust that connects via Ethernet and handles +24vdc logic.
Arturo Duncan
https://cnc4pc.com
Post by: Green4020 on December 16, 2025, 10:17:29 AM
I just have the one UC100 motion controller.  There isn't a second one.
Post by: JohnHaine on December 16, 2025, 10:37:28 AM
Arturo Duncan
https://cnc4pc.com
Who's trying to do that?  I need 2 for convenience, one for the mill and the other for the lathe, as moving one across would involved unscrewing covers etc.  What is slightly awkward is that I have to change over the other end of the USB cable as USB can't support "virtual" switching.
