Mach Discussion => General Mach Discussion => Topic started by: ROTex on November 25, 2025, 02:34:22 PM
I have an ancient system running Mach 3 on a Windows 7 pc through parallel ports to a motion control card driving servos. I want to change the hardware to a USB interface motion controller card. I'll get a new laptop and run Mach 3. What are the recommendations for a motion controller card and BOB?
Perhaps the easiest (and cheapest) solution would be to use a CncDrive UC100.
The UC400ETH is just a little more, and it is Ethernet. So much more reliable:
- Not sharing the grounds between the PC and CNC.
- Client-Server connection instead of running as a device on Windows.
- No significant cost difference.
Or even better, go with the Ethernet Smooth Stepper, which is fully compatible with Mach4 so that you can upgrade when you need to.
Arturo Duncan
https://cnc4pc.com
