Mach Discussion => Mach4 General Discussion => Topic started by: lgr on November 20, 2025, 06:40:55 PM
I downloaded Mach4 hobby and copied the screen set and .ini file to the new computer. When I unplug the ethernet cable on the Hicon 7866 from the old computer and plug in the new computer the new computer gives an estop error and won't allow me to enable. If I change the estop input signal from high to low it allows me to enable and then says Z home switch is activated, which it isn't I tried reversing the input signal on the Z axis as well and it didn't make a difference. I'm wondering if I missed a file in the transfer or something else? Both computers are windows 10 and Mach4 and Hicon plug-ins are the same versions. Thanks for any suggestions.
Try looking in your \Mach4Hobby\Profiles\your-profile-name folder to see if there are other files that should have been copied.
Likewise check the folders \Mach4Hobby\Modules and \Mach4Hobby\PMC to see if Hicon has any magic stuff there.
thanks Steve, I got it sorted. it was an ip issue sorry it took so long to respond.
