Mach Discussion => Mach4 General Discussion => Topic started by: eqrico2017 on September 29, 2025, 05:27:15 PM
I need to setup MACH 4 for tangential cut.
Does MACH 4 for Hobbyist version include this option?
Thank You,
EQ
Yes, tangential is supported in Mach 4.
Go to the screen for: Configure > Control and select the Defaults tab.
Then look down the left side of the screen, the second block is a setting for "Control Mode".
In the drop down list for Control Mode you will find the option for Tangential.
