Mach Discussion => General Mach Discussion => Topic started by: manivelle on June 19, 2025, 04:57:29 AM
Title: G31 probing workaround with accuracy and without getvar(2002) limitations
Post by: manivelle on June 19, 2025, 04:57:29 AM
Here is my code for to avoid var(2002) issues on cheap controllers. (mine is a WixHC MKX-ET https://www.wixhc.com/en/pc/243.html (https://www.wixhc.com/en/pc/243.html)).
The code is used on 4 different macros:
M1001 is TOOL LENGTH PROBE
M1002 is SET JOB Z ZERO
M1003 is TOOL CHANGE
M1004 is REF TOOL OFFSET
The code uses VB and DROs more than G-CODE. Most of the calculation are based on Machine Coordinates to avoid mistakes.
It's adapted to both imperial and metric systems.
Custom DROs are based on DarkScreen screenset, that I had to adapt a little bit.
You can find it all in the zip file and code is shown below.
Code: [Select]
' M1001
' TOOL LENGTH PROBE Macro with workaround concerning G31 limitations on chinese controlers
' Base code written by Big-Tex May 25 2010
' Mod David Marmilloud 06/2025 version 2025-0617.1 to work woith "DarkScreen DPD MM 23 03 27"
' https://www.machsupport.com/forum/index.php?topic=41912.60
InitialFeed = GetOemDRO(818) 'get the Initial feedrate to return to later
InitialAbsInc = GetOemLED(48) 'Get the Initial G90/G91 state
InitialWorkZ = GetOEMDRO(180) 'Get the Initial WORK Z position
Main
Sub Main()
'//////// Unit dependent parameters
If GetOEMLED(801) Then 'if unit is imperial (inches)
FirstProbeFeed = 8 'Approach Probe Feed Speed
SecondProbeFeed = 1 'Slow Probe Feed Speed
ProbeDepth = 10 'probing Depth
Res = 0.001 'set the measurement resolution
Else 'if unit is metric
FirstProbeFeed = 200.0 'Approach Probe Feed Speed
SecondProbeFeed = 30.0 'Slow Probe Feed Speed
ProbeDepth = 190 'Probing Depth
Res = 0.01 'set the measurement resolution
End If
'//////// Error Condition checking code
If GetOEMLED(16) Then 'Checks for machine coordinates
DoOEMButton(256) 'toggle to program coordinates
End If
If GetOEMLED(825)<>0 Then 'check probe first see if it is grounded
Code "(Probe Grounded, check connection and try again)" 'Status Bar display
End 'ERROR! exit the macro
End if
If GetOEMLED(807) or GetOEMLED(808) or GetOEMLED(809) Then 'Check all axes have been referenced
Code "(Ref all axis prior to Zero Z)" 'Status Bar display
End If
'//////// Get Tool change, and Tool measurement positions
ToolLoadXPos = GetOEMDRO(1150) 'Get tool load X position
ToolLoadYPos = GetOEMDRO(1151) 'Get tool load Y position
ToolLoadZPos = GetOEMDRO(1152) 'Get tool load Z position
ToolSensorXPos = GetOEMDRO(1006) 'Get Tool probe X position
ToolSensorYPos = GetOEMDRO(1007) 'Get Tool probe Y position
RefToolZOffset = GetOEMDRO(1008) 'Get Z offset, corresponding to REF tool Z position
'//////// Move to probe position
Code "G90 G0 G53 Z" & getOEMDRO(54) 'Move to Safe Z
Code "G90 G0 G53 X" & ToolSensorXPos & "Y" & ToolSensorYPos 'Move to Tool sensor position
'//////// Probing, first using G31, then refining with iterative method
Code "G4 P1" 'pause 1 seconds to give time to position probe plate
Code "F" & FirstProbeFeed 'First approach feedrate using G31
Code "(Probing)"
Code "G91 G31 Z-" & ProbeDepth 'probe move to probedepth - First travel
While IsMoving() 'wait for probe move to finish
Wend
Code "(1st touch)"
Code "F" & SecondProbeFeed 'set slow feedrate
ProbedZABS = GetZ(Res*10) 'Probing up to Low signal as Low res
ProbedZABS = GetZ(-Res) 'Probing down to High signal at High Res
ToolNumber = GetOEMDRO(824) 'get tool number
If ToolNumber <> 0 Then 'if not ref tool
Tool_Offset = ProbedZABS - RefToolZOffset 'Offset = This tool sensed position - Ref tool sensed positon
Call setOEMDRO(42, Tool_Offset) 'write it to current tool offset DRO
Code "G4 P.25" 'pause for Dro to update.
Code "(Tool #" & Tool_Num & " Offset is now set to" & ToolOffset &")"
Else 'if tool is ref tool
Ret = MachMsg("Ref Tool is active" & Chr(13) & Chr(10) & "Press OK to set Spindle Z offset," & Chr(13) & Chr(10) & "otherwise press CANCEL to abort", "WARNING", 1)
If Ret = 1 Then 'If answered OK
Call setOEMDRO(1008, ProbedZABS)'write sensed ABS position to Tool Setter Z offset
Code "(Ref tool is set ans stored on Settings Screen - Tool Setter coordinates Z)"
Else 'if answerd CANCEL
Code "(Set up canceled)"
RestoreInit
End If
End If
RestoreInit 'restore initial conditions
End Sub
Function GetZ(ResStep) As Double
'//////// Start Probing Code, Probe In -Z direction.
'//////// The vars will be Inch or Metric from above if/else statment
PlateOffset = GetOEMDRO(1001) 'get plate offset DRO
InitialContact = GetOEMLED(825) 'get probe contact state
i=0
Code "(Refining contact by " & ResStep & " step)"
While GetOEMLED(825)=InitialContact
'as long as the limit switch is ON
Code "G91 G1 Z" & ResStep 'move one step
Wend
i = i+1 'count steps
If i=30 Then 'If probe moved more than 20 steps without switching
Code "(Can't reach the sensor. ABORTED)" 'ERROR!
End 'End the program
End If
Wend 'loop
Code "(Got it)"
GetZ = GetOEMDRO(85) - PlateOffset 'Return new touch point in Machine coordinates
End Function
Sub RestoreInit()
'////////// restoring initial conditions
Code "G90 G0 Z" & InitialWorkZ 'Move to initial work Z position
Wend
If InitialAbsInc = 0 Then 'if G91 was in effect before then return to it
Code "G91"
Else
Code "G90"
End If
Call SetOEMDRO(818, InitialFeed) 'restore feed rate
End Sub
Code: [Select]
' M1002
' SET JOB Z ZERO Macro with workaround concerning G31 limitations on chinese controlers
' Mod David Marmilloud 03/2025 version 2025-0617.1 to work woith "DarkScreen DPD MM 23 03 27"
InitialAbsX = GetOEMDRO(83) 'Get the Initial MACHINE X position
InitialAbsY = GetOEMDRO(84) 'Get the Initial MACHINE Y position
InitialAbsZ = GetOEMDRO(85) 'Get the Initial MACHINE Z position
Main
Sub Main()
InitialAbsZ = GetOEMDRO(85) 'Get the Initial Z position
CurrentTLO = GetOEMDRO(42) 'Get the current tool length offset
ProbeDepth = 2 'probing Depth
FirstProbeFeed = 50.0 'Approach Probe Feed Speed
SecondProbeFeed = 10.0 'Slow Probe Feed Speed
ProbeDepth = 20 'Probing Depth
End If
End If
End if
End If
Code "(Probing)"
Wend
Code "(1st touch)"
PartZOffset = ProbedZABS - CurrentTLO 'Part Z Offset = Probed Z ABS value - Tool Length Offset
Call SetOEMDRO (49, - GetOEMDRO(49)) 'Reset the Work Z offset (it's a workaround, because this DRO acts strange : it adds typed values instead of replacing them)
Call SetOEMDRO (49, PartZOffset) 'Job Z zero = Current MachineABS position - MachineABS probed point)
Code"(Z axis is zeroed for this job)"
RestoreInit 'Restore initial conditions
End Sub
PlateOffset = GetOEMDRO(1161) 'get plate offset DRO
i=0
Wend
End If
Wend 'loop
Code "(Got it)"
GetZ = GetOEMDRO(85) - PlateOffset 'store new touch point in Machine coordinates
End Function
Sub RestoreInit()
'Code "G90 G0 G53 Z" & getOEMDRO(54) 'Move to Safe Z
'Code "G90 G0 G53 X" & InitialAbsX & "Y" & InitialAbsY 'Move to initial position
Code "G90 G0 G53 Z" & InitialAbsZ 'Move to initial Z position - Be carefull before uncomment. if tool is longer than previous, you migth crash
'Code "G90 G0 Z" & InitialWorkZ 'Move to initial work Z position
Wend
Code "G91"
Else
Code "G90"
End If
End Sub
Code: [Select]
' M1003
' TOOL CHANGE Macro with workaround concerning G31 limitations on chinese controlers
Main
Sub Main()
End If
End If
End if
End If
'//////// Move to tool position
Code "G90 G0 G53 X" & ToolLoadXPos & "Y" & ToolLoadYPos 'Move to Tool load position
Code "G90 G0 G53 Z" & ToolLoadZPos 'Move to Z load position
While IsMoving() 'wait for move to finish
Wend
If MachMsg("Change the tool to #" & ToolNumber & Chr(13) & Chr(10) & "Press OK when done, CANCEL to go skip probing", "MANUAL TOOL CHANGE", 1)=2 then
End 'Exit the macro if probing is unwanted
End if
Code "(Probing)"
Wend
Code "(1st touch)"
RestoreInit
End If
End If
End Sub
i=0
Wend
End If
Wend 'loop
Code "(Got it)"
End Function
Sub RestoreInit()
'Code "G90 G0 G53 Z" & InitialAbsZ 'Move to initial Z position - Be carefull before uncomment. if tool is longer than previous, you migth crash
Wend
Code "G91"
Else
Code "G90"
End If
End Sub
Title: Re: G31 probing workaround with accuracy and without getvar(2002) limitations
Post by: manivelle on June 19, 2025, 05:05:21 AM
Code: [Select]
' M1004
' SET TOOL SETTER Z OFFSET Macro with workaround concerning G31 limitations on chinese controlers
' Mod David Marmilloud 03/2025 version 2025-0325.1 to work woith "DarkScreen DPD MM 23 03 27"
Main
Sub Main()
End If
End If
End if
End If
'//////// Get Tool measurement positions
Code "(Probing)"
Wend
Code "(1st touch)"
MachMsg("Tool number should be #0" & Chr(13) & Chr(10) & "Please set the ref tool and restart the procedure", "WARNING", 0)
Exit sub
End If
End Sub
i=0
Wend
End If
Wend 'loop
Code "(Got it)"
End Function
Sub RestoreInit()
Wend
Code "G91"
Else
Code "G90"
End If
End Sub
Code: [Select]
' M1004
Main
Sub Main()
End If
End If
End if
End If
Code "(Probing)"
Wend
Code "(1st touch)"
Exit sub
End If
End Sub
i=0
Wend
End If
Wend 'loop
Code "(Got it)"
End Function
Sub RestoreInit()
Wend
Code "G91"
Else
Code "G90"
End If
End Sub
