Mach Discussion => General Mach Discussion => Topic started by: FiberglassMan on June 09, 2025, 01:40:24 PM
I am sure this question was asked multiple times, but didn't see many answers and things change.
Using windows 10( No Parallel port)
What is the best most reliable controller? e.g. (Smooth stepper .....)
I have tried lots of different controllers but is seems each one of them have some odd issues.
Thanks in advance
CT-
I use 2 UC100s, one on mill and one lathe. Works very well.
Best I have found is a CS-LABS motion controller. However they have become expensive now. But I had one on my milling machine and it just worked from the start. Now I am stuck trying too figure out why the UC100 is not moving the stepper motors.
Did you make sure to buy genuine ones? There are apparently clones around - best to buy from a genuine CNCDrive stockist. Where are you based?
Did you download/install the plugin for the device, and configure it?
Can you tell us what steps you have followed to configure mach 3? I found that most of the settings I was using for the parallel port carried across directly.
Ethernet Smooth Stepper with latest driver. Very Very reliable and complete.
Roger
