Mach Discussion => General Mach Discussion => Topic started by: jimthefish on January 14, 2025, 05:02:49 AM
Title: overshot X axis using Mach 3 software
Post by: jimthefish on January 14, 2025, 05:02:49 AM
Working in a very tight area and unfortunately pressed X+ instead of X- and over shot the limit switch. How do I get the machine to allow me to jog off, Cannot get the rest button to stop on, so cannot do any moves.?
Title: Re: overshot X axis using Mach 3 software
Post by: JohnHaine on January 14, 2025, 07:24:05 AM
Go into config and disable the limit switch.
Post by: jimthefish on January 14, 2025, 08:00:00 AM
Cheers John, I've been using this machine for 25years and thought i would test it one last time before selling it and pressed x+, I put it down to my old age
Post by: JohnHaine on January 14, 2025, 12:22:20 PM
HTH Remember to re-enable it!
Post by: jimthefish on January 15, 2025, 01:44:30 PM
Done, Thanks mate
Post by: TPS on January 16, 2025, 06:59:40 AM
in Settings (Alt-6) screen is a button called
OverRide Limits
for this situation, it will allow you to jog off the limit switch and will be disabled
automatcly if the limit switch is free. so nothing to change in config and nothing
will be forgoten.
