Mach Discussion => Mach4 General Discussion => Topic started by: M_Sund on October 30, 2024, 05:28:57 PM
I am trying to get cutter comp to work and I do not know if it is possible using the hobby version. On day two of trying to get this to work. I was using Fusion 360 but when my subscription lapsed, they started posting out G01 as G00 so it tends to slow things way down.
Here is what I am trying to use this is just a simple program to see if I could get it to work.
G0 G90 G54 G40 G49 G20 G17 G94 G80
T01 M06
G41 P0.0625 G00 X-2.5 Y2.5
G01 Z-.020 F20
G01 X-2 Y2
X2
Y-2
X-2
Y2.25
G00 Z.100
G40
M30
Cutter comp does work in Mach4 with code posted from Fusion. I used to use it all the time when I had a Mach4 mill that I ran all my parts on.
You just need to make sure the that you are using the Compensation Type as "In Control" under the passes tab in your toolpath.
Also, I don't see a "D" value on your G41 line, so it isn't using the diameter of your tool.
