Mach Discussion => General Mach Discussion => Topic started by: Steve1307 on July 25, 2024, 09:58:18 PM
Title: Travel in Wrong Direction
Post by: Steve1307 on July 25, 2024, 09:58:18 PM
I have just got my machine going with a lot of help this forum,but when jogging the X axis is the wrong way. In other words from the Home Position, bottom-left I need to push the Left Hand arrow key to move to the right and the DRO display increasing Negative numbers. The wiring in the controller is identical for  X Y Z axis so I was hesitant to change it there. Is there any where in Mach3 to correct this problem?
Title: Re: Travel in Wrong Direction
Post by: TPS on July 26, 2024, 12:37:43 AM
Config -> Ports&Pins -> Motor Outputs -> Dir Low active
should help
Post by: Steve1307 on July 26, 2024, 01:06:58 AM
Thankyou, that did the trick
