Mach Discussion => General Mach Discussion => Topic started by: Whacko on November 15, 2007, 04:49:57 PM
Title: Rapid traverse
Post by: Whacko on November 15, 2007, 04:49:57 PM
Ok, someone please tell me how to force the Rapid Traverse "G0" to travel at the max motor speed setting, or the rapid overide dro setting. I'll buy you a beer, or maybe two!
Whacko!
Title: Re: Rapid traverse
Post by: Chaoticone on November 15, 2007, 05:30:49 PM
Do you mean hold down shift and the axis jog key at the same time? If this is it, I can't drink beer, it makes me drunk.
Post by: Whacko on November 15, 2007, 11:51:41 PM
Ok, a diet soda then? With some Bourbon? Thanks for the reply Brett. No its when Mach executes a part program. With the g0 lines, the speed is the same as the feedrate. I got the max speed at 35 meters per minute in the motor tuning setup. The rapid feedrate set at 25 meters per minute.
After a g1 line, the g0 command to get to the next cut point is not a rapid traverse, just the same speed as the g1 feedrate. I had this one before, and fixed it, now I'm stuck between a Dead brain and a Brick wall. I just cant remeber what I did to fix it.
Whacko for Bourbon
Post by: Chaoticone on November 16, 2007, 05:14:46 AM
LOL, Did you ref. all home?
Post by: vmax549 on November 16, 2007, 06:52:29 AM
Perhaps you are lifting z at the same time? THen it wll only move at the slowest axis speed??
Just a thought,(;-) TP
Post by: Whacko on November 16, 2007, 11:46:58 AM
It's in Plasma mode with THC, so the Z is used for the torch up/down. Yep all referenced home. I'm going home now too! I will fight the demon in the morning. I think I can control the rapids with some macro's. If not, I'll shout! Guess I ain't buying the beers tonight. But if I'm out your way, I'll buy you a few rounds anyway! Cause I'm a good guy!
Whacko for goodness!
