Mach Discussion => Mach4 General Discussion => Topic started by: ROTM on April 29, 2024, 04:48:17 PM
Title: How and where to adjust plasma Z after cut has finished
Post by: ROTM on April 29, 2024, 04:48:17 PM
Good day.
When I cut with my router ...and after it has finished the router will go to x0 y0 that has been set.
and the lift the Z 0.8" the bit height from the work.
I would like for the plasma to behave the same...
between cuts it will lift at a set height that I put in Mach4 (Avid) but at the end of the cut it will go x0 y0
Parking set in sheetcam but the Z will lift all the way up.
Anyone know where I need to set the value?
Thank you!
Title: Re: How and where to adjust plasma Z after cut has finished
Post by: ROTM on May 02, 2024, 10:45:49 PM
Nevermind sheetcam has an option in the postprocessor at add distance.
